Saltar al contenido principal
Dell Inspiron Mini 10 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: paso 4, imagen 1 de 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron Mini 10 Keyboard Replacement: paso 5, imagen 2 de 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron Mini 10 Keyboard Replacement: paso 6, imagen 2 de 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
Conclusión
Equipo
UW Tacoma, Team 1-4, Rose Fall 2016 Miembro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,333
