Introducción
This guide will take you through accessing and removing the hard drive. The hard drive is an important component because it stores operating system software and your files. Keep it away from magnets as they may demagnetize the part, causing loss of information.
Qué necesitas
Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
3 personas más completaron esta guía.
