Qué necesitas
Loosen the captive screw that secures the module cover to the base cover
Using your fingertips, release the tabs on the module cover from the slots on the computer base
Lift the module cover off the computer base
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
Remove the memory module from the memory-module connector.
align the notch in the memory module with the tab in the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Replace the module cover
Replace the battery
Una persona más ha completado esta guía.
