Saltar al contenido principal
Dell Inspiron M5010 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron M5010 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron M5010 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Keyboard Replacement, Remove keyboard retaining screw: paso 2, imagen 1 de 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron M5010 Keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron M5010 Keyboard Replacement: paso 3, imagen 3 de 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Keyboard Replacement: paso 4, imagen 1 de 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Keyboard Replacement: paso 5, imagen 1 de 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
Conclusión
Una persona más ha completado esta guía.
April Poucher
Miembro Desde 10/13/14
1,164 Reputación
10 Guías creadas
Equipo
Clemson, Team 1-5, Benson Fall 2014 Miembro de Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 722
