Saltar al contenido principal
Dell Inspiron E1705 Optical Drive Replacement
Qué necesitas
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: paso 2, imagen 1 de 2 Dell Inspiron E1705 Optical Drive Replacement: paso 2, imagen 2 de 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: paso 4, imagen 1 de 2 Dell Inspiron E1705 Optical Drive Replacement: paso 4, imagen 2 de 2
    • Use the screwdriver to gently push the optical drive out
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 22-5, Maness Fall 2010 Miembro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 11
Todo El Tiempo: 3,953
