Saltar al contenido principal
Partes
No se especificaron partes.
  1. Make sure that the computer is turned off and is disconnected from external power source.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Remove the 12 Phillips #1 screws from the edges of the lower case.
    • Remove the 12 Phillips #1 screws from the edges of the lower case.
    • You may also need to remove the central screw next to the lock icon.
  4. Turn the computer back over and tilt the screen open. Use the plastic opening tool to carefully pry the panel out as shown in the pictures Remove the plastic panel carefully.
    • Turn the computer back over and tilt the screen open.
    • Use the plastic opening tool to carefully pry the panel out as shown in the pictures
    • Remove the plastic panel carefully.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Use the small Phillips head screwdriver to remove the screws circled in red. Gently lift the keyboard up and rest it just below the screen as shown in the picture. The keyboard will still be connected to the motherboard.
    • Use the small Phillips head screwdriver to remove the screws circled in red.
    • Gently lift the keyboard up and rest it just below the screen as shown in the picture.
    • The keyboard will still be connected to the motherboard.
  7. Before removing the keyboard completely, use the plastic opening tool to gently lift the clamp connecting the keyboard to the motherboard. Once the keyboard has been disconnected, remove the keyboard completely.
    • Before removing the keyboard completely, use the plastic opening tool to gently lift the clamp connecting the keyboard to the motherboard.
    • Once the keyboard has been disconnected, remove the keyboard completely.
  8. Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them. Carefully unplug the connections shown. Don't forget the display cable.  It is slightly to the right of the Dell logo at the top.
    • Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
    • Carefully unplug the connections shown.
    • Don't forget the display cable. It is slightly to the right of the Dell logo at the top.
    • Also, the wireless cables on the right side may prevent moving the upper case out of the way.
    • Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
  9. Remove the plastic case by gently bending back towards the screen.  You can bend the screen all the way back if that helps.
    • Remove the plastic case by gently bending back towards the screen. You can bend the screen all the way back if that helps.
    • For the motherboard the optical drive will be removed already. However for the lower case it is not necessary that it be taken out.
    • If you are having trouble removing the upper plastic case (and LCD) from the lower case, there may still be a wire connected to the Wi-Fi adapter. Turn the laptop over, open the Wi-Fi module access panel and remove the + and - leads for the Wi-Fi antenna.
  10. Unscrew the 4 screws shown in the picture.
    • Unscrew the 4 screws shown in the picture.
    • Screws will not come out all the way.
  11. Remove the heat sync gently Remove the heat sync gently
    • Remove the heat sync gently
  12. The right heat sync is connected to the videocard. To remove the heat sync requires also removing the videocard. Remove the 4 screws indicated in the first picture Screws will not totally come out.
    • The right heat sync is connected to the videocard. To remove the heat sync requires also removing the videocard.
    • Remove the 4 screws indicated in the first picture
    • Screws will not totally come out.
    • Gently lift up the videocard and heat sync from the motherboard.
Conclusión
2 personas más completaron esta guía.
Malik Shahbal
Miembro Desde 05/10/10
435 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 22-5, Maness Fall 2010 Miembro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 3,977
