Saltar al contenido principal
Dell Inspiron E1505 Battery Replacement
  1. Dell Inspiron E1505 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Battery Replacement: paso 2, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Battery Replacement: paso 3, imagen 1 de 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Battery Replacement: paso 4, imagen 1 de 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
Conclusión
Anthony Toscano
Miembro Desde 10/20/16
323 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 6-7, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 601
