Saltar al contenido principal
Dell Inspiron B130 RAM and Wireless Replacement
Qué necesitas
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: paso 1, imagen 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: paso 2, imagen 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 2, imagen 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 2, imagen 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: paso 3, imagen 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 3, imagen 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 3, imagen 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: paso 4, imagen 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: paso 4, imagen 2 de 2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: paso 5, imagen 1 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 5, imagen 2 de 3 Dell Inspiron B130 RAM and Wireless Replacement: paso 5, imagen 3 de 3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: paso 6, imagen 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement: paso 6, imagen 2 de 2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: paso 7, imagen 1 de 2 Dell Inspiron B130 RAM and Wireless Replacement: paso 7, imagen 2 de 2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Conclusión
Una persona más ha completado esta guía.
Patrick McNeil
Miembro Desde 10/19/16
937 Reputación
8 Guías creadas
Equipo
UMass Dartmouth, Team 1-8, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 279
