Introducción
Replacing the motherboard is rarely if ever needed. Any kind of issue with the computer not starting or it ending up freezing are almost always related to other hardware problems. If you know for a fact that it is not any other pieces of hardware then use this guide to replace the motherboard on your Dell B130.
Qué necesitas
Remove the battery by flipping the two switches under the battery and pulling it out
Remove the 8mm screw
Use the plastic opening tool to push out the disk drive.
Pull the disk drive out with the opposite hand.
This particular computer is missing its hard drive.
Remove the two screws.
Remove the plastic cover by lifting from the groove as indicated.
Remove the hard drive from the computer by lifting up and out.
Put down the computer and open up the screen.
There is a long piece of plastic underneath the screen that you will have to remove.
This reveals two connections that must be removed.
Remove the one with the blue tape by lifting up on the tape gently.
Remove the three 6mm screws.
Lift the plastic cover off to reveal the RAM and the Wireless.
