Introducción
This guide will show you how to replace the cooling fan for your Dell B130. The cooling fan keeps the internals of the laptop cool so it can run efficiently. Some problems that arise when this is not functioning correctly is when the computer will turn off suddenly or it is running very slow.
Qué necesitas
Remove the battery by flipping the two switches under the battery and pulling it out
Remove the 8mm screw
Use the plastic opening tool to push out the disk drive.
Pull the disk drive out with the opposite hand.
This particular computer is missing its hard drive.
Remove the two screws.
Remove the plastic cover by lifting from the groove as indicated.
Remove the hard drive from the computer by lifting up and out.
Put down the computer and open up the screen.
There is a long piece of plastic underneath the screen that you will have to remove.
This reveals two connections that must be removed.
Remove the one with the blue tape by lifting up on the tape gently.
Remove the three 6mm screws.
Lift the plastic cover off to reveal the RAM and the Wireless.
Remove these four 4 mm screws.
Turn the motherboard over and lift the fan up.
Disconnect the wire that connects the fan to the motherboard by pulling up gently.
You can now remove the fan.
Una persona más ha completado esta guía.
