Saltar al contenido principal
Dell Inspiron B130 CPU Replacement
Qué necesitas
  1. Dell Inspiron B130 CPU Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron B130 CPU Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron B130 CPU Replacement, Battery: paso 1, imagen 3 de 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 CPU Replacement: paso 2, imagen 1 de 3 Dell Inspiron B130 CPU Replacement: paso 2, imagen 2 de 3 Dell Inspiron B130 CPU Replacement: paso 2, imagen 3 de 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 CPU Replacement: paso 3, imagen 1 de 3 Dell Inspiron B130 CPU Replacement: paso 3, imagen 2 de 3 Dell Inspiron B130 CPU Replacement: paso 3, imagen 3 de 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 CPU Replacement, CPU: paso 4, imagen 1 de 2 Dell Inspiron B130 CPU Replacement, CPU: paso 4, imagen 2 de 2
    • Remove the 6 mm screw.
    • Lift the plastic cover off.
  5. Dell Inspiron B130 CPU Replacement: paso 5, imagen 1 de 2 Dell Inspiron B130 CPU Replacement: paso 5, imagen 2 de 2
    • Loosen the 4 screws.
    • These screws stay connected to the heat sink.
    • Remove the heat sink from the computer.
  6. Dell Inspiron B130 CPU Replacement: paso 6, imagen 1 de 1
    • Use a flat head screwdriver to turn the screw one quarter turn into the unlock position.
    • Remove the CPU.
Conclusión
2 personas más completaron esta guía.
Patrick McNeil
Miembro Desde 10/19/16
937 Reputación
8 Guías creadas
Equipo
UMass Dartmouth, Team 1-8, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 372
