Saltar al contenido principal
Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
Qué necesitas
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: paso 1, imagen 3 de 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 2, imagen 1 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 2, imagen 2 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 2, imagen 3 de 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: paso 3, imagen 1 de 2 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: paso 3, imagen 2 de 2
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 4, imagen 1 de 1
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 5, imagen 1 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 5, imagen 2 de 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: paso 5, imagen 3 de 3
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusión
Una persona más ha completado esta guía.
charlierefvem
Miembro Desde 01/11/11
854 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 4,293
