Introducción
This guide requires a Phillips #00 screwdriver
Partes
No se requieren partes.
  1. Unplug the laptop from the power adapter and turn the power off.
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
    • Disconnect the antenna cables from the Mini-PCI card.
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusión
Una persona más ha completado esta guía.
charlierefvem
Miembro Desde 11/01/11
854 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 3,991
