Saltar al contenido principal
Dell Inspiron 9100 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 9100 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 9100 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 2, imagen 3 de 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: paso 4, imagen 1 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 4, imagen 2 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 4, imagen 3 de 3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 5, imagen 3 de 3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: paso 6, imagen 1 de 1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: paso 7, imagen 1 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 7, imagen 2 de 3 Dell Inspiron 9100 Keyboard Replacement: paso 7, imagen 3 de 3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
Conclusión
Una persona más ha completado esta guía.
Ana
Miembro Desde 01/11/11
111 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 3,976
