Saltar al contenido principal
Dell Inspiron 910 Screen Replacement
Qué necesitas
  1. Dell Inspiron 910 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Screen Replacement, Screen: paso 2, imagen 1 de 1
    • Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
  3. Dell Inspiron 910 Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
  4. Dell Inspiron 910 Screen Replacement: paso 4, imagen 1 de 1
    • Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
    • Unscrew the 4 screws from the two strips.
    • While unscrewing the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
  5. Dell Inspiron 910 Screen Replacement: paso 5, imagen 1 de 1
    • Gently lay the screen down, being careful not to damage the ribbon connector.
  6. Dell Inspiron 910 Screen Replacement: paso 6, imagen 1 de 1
    • Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
  7. Dell Inspiron 910 Screen Replacement: paso 7, imagen 1 de 1
    • Pull the screen out. Congratulations! You have removed the screen.
Conclusión
2 personas más completaron esta guía.
Kyle Beekman
Miembro Desde 04/05/12
144 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Spring 2012 Miembro de Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 2,481
