Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
In this guide it will be demonstrated how to replace the memory on a Dell Inspiron 910 laptop.
Partes
No se especificaron partes.
  1. Locate the release tabs located on either side of the battery, on the bottom of the laptop.
    • Locate the release tabs located on either side of the battery, on the bottom of the laptop.
    • Push the release tabs toward the center of the device.
    • Remove the battery.
  2. Remember to power off the device before starting!
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Remove the panel by pulling upward.
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. After removing the panel, locate the memory modules. Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
Conclusión
4 personas más completaron esta guía.
Kyle Beekman
Miembro Desde 05/04/12
144 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Spring 2012 Miembro de Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 2,603
