Saltar al contenido principal
Dell Inspiron 8600 Video Card Replacement
Qué necesitas
  1. Dell Inspiron 8600 Video Card Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: paso 2, imagen 1 de 3 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: paso 2, imagen 2 de 3 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: paso 2, imagen 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Video Card Replacement: paso 3, imagen 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Video Card Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Inspiron 8600 Video Card Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Inspiron 8600 Video Card Replacement, Keyboard: paso 4, imagen 3 de 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Video Card Replacement, Video Card: paso 5, imagen 1 de 3 Dell Inspiron 8600 Video Card Replacement, Video Card: paso 5, imagen 2 de 3 Dell Inspiron 8600 Video Card Replacement, Video Card: paso 5, imagen 3 de 3
    • After removing the keyboard, locate and remove the labeled screws.
    • Gently lift the Video Card unit for replacing.
Conclusión
3 personas más completaron esta guía.
Brian Murphy
Miembro Desde 04/13/11
368 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 7,045
