Introducción
This guide will show you how to remove and replace the processor unit.
Partes
No se requieren partes.
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
    Agregar Comentario
  2. Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
    • Be careful of wire attached to underside of the hinge cover.
    Agregar Comentario
    • Pull the small black tab on the right hand side of the laptop.
    • The hinge cover has now been removed.
    Agregar Comentario
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
    Agregar Comentario
    • Lift the display module directly upwards from the base of the computer.
    Agregar Comentario
    • The display module has been removed.
    Agregar Comentario
    • Locate and remove the top two screws and all the screws on the underside holding the top case down.
    • Gently pop off the top plastic case from the unit.
    Agregar Comentario
    • Remove the copper heat sink that is housing the CPU by removing the four securing screws.
    • Gently lift and remove the heat sink.
    Agregar Comentario
    • Gently loosen but do not remove the screw, and lift the CPU.
    • You will have to remove and replace the Como aplicar pasta termica on the CPU base.
    • You may now replace the CPU.
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
John Nesthus
Miembro Desde 13/04/11
186 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
16 Guías creadas
you can actually Simplify this a Lot by removing the fan on the bottom shown in Step 1 upper Right side then once you get to step 8 you only have to remove the screws for the processor heatsink and then bam your processor is able to be removed or replaced
DW
Duane Wasylyshen - Contestar
The Dell Inspiron 8600 I have (not sure the year) I had to remove the keyboard to access the CPU.. Remove two screws holding the keyboard down and lift on the white tab. Remove the fan (two screws and the fan comes right out).. That give you more room to remove the heat exchanger. Other than that it was SUPER EASY !!! Thanks
nycny10025 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 6,440
