Saltar al contenido principal
Dell Inspiron 8600 Power Button Replacement
Qué necesitas
  1. Dell Inspiron 8600 Power Button Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: paso 2, imagen 1 de 3 Dell Inspiron 8600 Power Button Replacement, Power Button: paso 2, imagen 2 de 3 Dell Inspiron 8600 Power Button Replacement, Power Button: paso 2, imagen 3 de 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: paso 3, imagen 1 de 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
Conclusión
3 personas más completaron esta guía.
Brian Murphy
Miembro Desde 04/13/11
368 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 4,134
