Saltar al contenido principal
Dell Inspiron 8600 LCD Replacement
Qué necesitas
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: paso 1, imagen 1 de 3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: paso 1, imagen 2 de 3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: paso 1, imagen 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: paso 2, imagen 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: paso 3, imagen 1 de 2 Dell Inspiron 8600 LCD Replacement, Display Module: paso 3, imagen 2 de 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: paso 4, imagen 1 de 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: paso 5, imagen 1 de 2 Dell Inspiron 8600 LCD Replacement: paso 5, imagen 2 de 2
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: paso 6, imagen 1 de 1
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: paso 7, imagen 1 de 3 Dell Inspiron 8600 LCD Replacement, LCD: paso 7, imagen 2 de 3 Dell Inspiron 8600 LCD Replacement, LCD: paso 7, imagen 3 de 3
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: paso 8, imagen 1 de 1
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: paso 9, imagen 1 de 1
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: paso 10, imagen 1 de 1
    • Remove the broken LCD unit, and replace with new unit.
Conclusión
2 personas más completaron esta guía.
Perry
Miembro Desde 04/12/11
251 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
16 Guías creadas
Un comentario
which controller board do i have to use for this model ?
bcdoor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 4,662
