Saltar al contenido principal
Dell Inspiron 8600 Display Removal
Qué necesitas
  1. Dell Inspiron 8600 Display Removal, Battery: paso 1, imagen 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: paso 2, imagen 1 de 3 Dell Inspiron 8600 Display Removal, Hinge Cover: paso 2, imagen 2 de 3 Dell Inspiron 8600 Display Removal, Hinge Cover: paso 2, imagen 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: paso 3, imagen 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: paso 4, imagen 1 de 2 Dell Inspiron 8600 Display Removal, Display Module: paso 4, imagen 2 de 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: paso 5, imagen 1 de 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: paso 6, imagen 1 de 2 Dell Inspiron 8600 Display Removal: paso 6, imagen 2 de 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Display Removal: paso 7, imagen 1 de 1
    • Now remove the display module.
Conclusión
2 personas más completaron esta guía.
Victor
Miembro Desde 04/06/11
187 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 3,877
