Saltar al contenido principal
Dell Inspiron 7590 Battery Replacement
Qué necesitas
  1. Dell Inspiron 7590 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 7590 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
    • Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
  2. Dell Inspiron 7590 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 7590 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 7590 Battery Replacement: paso 2, imagen 3 de 3
    • Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
    • Separate the remainder of the paneling using an Opening Pick.
    • Avoid using a metal utensil when separating the remainder of the paneling to avoid paint chipping.
  3. Dell Inspiron 7590 Battery Replacement: paso 3, imagen 1 de 3 Dell Inspiron 7590 Battery Replacement: paso 3, imagen 2 de 3 Dell Inspiron 7590 Battery Replacement: paso 3, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the three screws securing the battery.
  4. Dell Inspiron 7590 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 7590 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, disconnect the ribbon cable connecting the battery to the motherboard.
  5. Dell Inspiron 7590 Battery Replacement: paso 5, imagen 1 de 2 Dell Inspiron 7590 Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the device.
Conclusión
2 personas más completaron esta guía.
Un comentario
Hello,
I noticed in your tear down there are two ram slots. I tried to find this information online, but was unable to. Are any of those ram slots an empty slot, to possibly upgrade?
Dave Szes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 1,525
