Saltar al contenido principal
Dell Inspiron 7586 2-in-1 SSD Replacement
Qué necesitas
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: paso 1, imagen 1 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: paso 1, imagen 2 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: paso 1, imagen 3 de 3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: paso 2, imagen 1 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement: paso 2, imagen 2 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: paso 3, imagen 1 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement: paso 3, imagen 2 de 3 Dell Inspiron 7586 2-in-1 SSD Replacement: paso 3, imagen 3 de 3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: paso 4, imagen 1 de 2 Dell Inspiron 7586 2-in-1 SSD Replacement: paso 4, imagen 2 de 2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
Conclusión
2 personas más completaron esta guía.
Mike03
Miembro Desde 03/05/24
139 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 83
