Saltar al contenido principal
Dell Inspiron 7573 2-in-1 Battery Replacement
Qué necesitas
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: paso 2, imagen 3 de 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: paso 4, imagen 1 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: paso 4, imagen 2 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: paso 4, imagen 3 de 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Conclusión
Una persona más ha completado esta guía.
Kylie Freese
Miembro Desde 09/27/21
405 Reputación
3 Guías creadas
Equipo
Casper College, Team 1-2, Lareau Fall 2021 Miembro de Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 53
Todo El Tiempo: 2,378
