Introducción
This guide will walk you through how remove the battery from the systems board of a Dell Inspiron 7573 2-in-1. This guide is useful for replacing a battery that may be defective or damaged such as if the battery may not be holding a full charge. If your battery isn’t holding charge like it used to, use this guide to replace it!
Qué necesitas
Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
Una persona más ha completado esta guía.
