Saltar al contenido principal
Dell Inspiron 7306 P125 Battery Replacement
Qué necesitas
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 7306 P125 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 7306 P125 Battery Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: paso 3, imagen 1 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 3, imagen 2 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 3, imagen 3 de 3
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 7306 P125 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: paso 5, imagen 1 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 5, imagen 2 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: paso 6, imagen 1 de 2 Dell Inspiron 7306 P125 Battery Replacement: paso 6, imagen 2 de 2
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: paso 7, imagen 1 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 7, imagen 2 de 3 Dell Inspiron 7306 P125 Battery Replacement: paso 7, imagen 3 de 3
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
Conclusión
Una persona más ha completado esta guía.
Arturo Gonzalez
Miembro Desde 03/29/23
172 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 75
Todo El Tiempo: 661
