Saltar al contenido principal
Dell Inspiron 6400 keyboard Replacement
Qué necesitas
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: paso 1, imagen 1 de 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: paso 1, imagen 2 de 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: paso 1, imagen 3 de 3
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 6400 keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 6400 keyboard Replacement: paso 2, imagen 3 de 3
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 6400 keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 6400 keyboard Replacement: paso 3, imagen 3 de 3
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: paso 4, imagen 1 de 3 Dell Inspiron 6400 keyboard Replacement: paso 4, imagen 2 de 3 Dell Inspiron 6400 keyboard Replacement: paso 4, imagen 3 de 3
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 6400 keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 6400 keyboard Replacement: paso 5, imagen 3 de 3
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 6400 keyboard Replacement: paso 6, imagen 2 de 2
    • Place the battery and lock it into place
Conclusión
kempc8
Miembro Desde 11/22/13
899 Reputación
7 Guías creadas
Equipo
K and K Fixit Miembro de K and K Fixit
Business
1 Miembro
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 898
