Saltar al contenido principal
Dell Inspiron 600m Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 600m Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 600m Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 600m Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Orient laptop with the keyboard facing upward and the lid open.
  3. Dell Inspiron 600m Keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 600m Keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 600m Keyboard Replacement: paso 3, imagen 3 de 3
    • Caution the face plate is a fragile piece of plastic. Handle carefully.
    • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
    • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
    • Carefully lift the screwdriver to remove the face plate.
  4. Dell Inspiron 600m Keyboard Replacement: paso 4, imagen 1 de 3 Dell Inspiron 600m Keyboard Replacement: paso 4, imagen 2 de 3 Dell Inspiron 600m Keyboard Replacement: paso 4, imagen 3 de 3
    • Use a the Phillips screwdriver to remove the two screws.
  5. Dell Inspiron 600m Keyboard Replacement: paso 5, imagen 1 de 1
    • Gently slide keyboard toward screen.
    • Lift keyboard carefully. It is attached by a ribbon cable.
  6. Dell Inspiron 600m Keyboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 600m Keyboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 600m Keyboard Replacement: paso 6, imagen 3 de 3
    • Pull upward on blue tab to disconnect keyboard.
Conclusión
3 personas más completaron esta guía.
Peter Hallsten
Miembro Desde 04/01/11
148 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-40, Forte Spring 2011 Miembro de Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 3,495
