Saltar al contenido principal
Dell Inspiron 6000 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: paso 2, imagen 1 de 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Inspiron 6000 Keyboard Replacement: paso 4, imagen 2 de 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: paso 5, imagen 1 de 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 6000 Keyboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 6000 Keyboard Replacement: paso 6, imagen 3 de 3
    • Gently pull the blue tab up until it comes away from computer.
Conclusión
5 personas más completaron esta guía.
Jacob DeWar
Miembro Desde 09/23/14
533 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-1, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Miembros
7 Guías creadas
Un comentario
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 2,072
