Saltar al contenido principal
Dell Inspiron 6000 DVD/CD Drive Replacement
Qué necesitas
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: paso 2, imagen 1 de 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: paso 3, imagen 1 de 1
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: paso 4, imagen 1 de 1
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: paso 5, imagen 1 de 1
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: paso 6, imagen 1 de 1
    • Using your hand, pull the disk drive out of the laptop.
Conclusión
Kenneth Odum
Miembro Desde 09/23/14
545 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 11-1, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,880
