Saltar al contenido principal
Dell Inspiron 5758 Heatsink and Fan Replacement
Qué necesitas
  1. Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 2, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 2, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 2, imagen 3 de 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: paso 3, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: paso 3, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: paso 3, imagen 3 de 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 4, imagen 1 de 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 5, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 5, imagen 2 de 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 6, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 6, imagen 2 de 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 7, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 7, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 7, imagen 3 de 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 8, imagen 1 de 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 9, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 9, imagen 2 de 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 10, imagen 1 de 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 11, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 11, imagen 2 de 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 12, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 12, imagen 2 de 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 13, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 13, imagen 2 de 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 14, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 14, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 14, imagen 3 de 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 15, imagen 1 de 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 16, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 16, imagen 2 de 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 17, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 17, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 17, imagen 3 de 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 18, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 18, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 18, imagen 3 de 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Heatsink and Fan Replacement, Heatsink and Fan: paso 19, imagen 1 de 1
    • After removing the bottom base, you can access the heatsink and fan, which is attached to the motherboard.
  20. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 20, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 20, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 20, imagen 3 de 3
    • Unplug the cable that connects the heatsink and fan to the motherboard.
  21. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 21, imagen 1 de 2 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 21, imagen 2 de 2
    • Loosen the three 5mm screws that connect the heatsink and fan to the motherboard.
    • The screws stay attached to the heatsink and fan. You cannot pull them out, only loosen them.
  22. Dell Inspiron 5758 Heatsink and Fan Replacement: paso 22, imagen 1 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 22, imagen 2 de 3 Dell Inspiron 5758 Heatsink and Fan Replacement: paso 22, imagen 3 de 3
    • Remove the heatsink and fan from the motherboard. You can now clean or replace it as you see fit.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 603
