Saltar al contenido principal
Dell Inspiron 5555 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 5555 Keyboard  Replacement, Battery: paso 1, imagen 1 de 1
    • Close the laptop and lay it flat, logo side down.
    • Make sure that the battery is visible and at the top of the device.
  2. Dell Inspiron 5555 Keyboard  Replacement: paso 2, imagen 1 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 2, imagen 2 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 2, imagen 3 de 3
    • Push the lock switch to the left to pop out the battery.
  3. Dell Inspiron 5555 Keyboard  Replacement: paso 3, imagen 1 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 3, imagen 2 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 3, imagen 3 de 3
    • When the battery pops out, lift it so that it comes out completely.
  4. Dell Inspiron 5555 Keyboard  Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Inspiron 5555 Keyboard  Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Inspiron 5555 Keyboard  Replacement, Keyboard: paso 4, imagen 3 de 3
    • Turn the laptop over and open the device.
    • Insert the flat end of the spudger into the five notches located at the top of the keyboard and pry the keyboard up by pushing down and up.
  5. Dell Inspiron 5555 Keyboard  Replacement: paso 5, imagen 1 de 2 Dell Inspiron 5555 Keyboard  Replacement: paso 5, imagen 2 de 2
    • Lift up and slide back to release the six notches from the bottom of the keyboard.
    • Be careful not to lift the keyboard up all the way because it is still connected to the laptop by a cable on the bottom.
  6. Dell Inspiron 5555 Keyboard  Replacement: paso 6, imagen 1 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 6, imagen 2 de 3 Dell Inspiron 5555 Keyboard  Replacement: paso 6, imagen 3 de 3
    • Flip the keyboard upside down to access the keyboard cable.
    • Using the flat end of the spudger, flip the black tab securing the keyboard cable up to remove the keyboard cable.
    • Remove the keyboard by lifting it off of the laptop.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Thank you so much for this guide! The steps were clear and concise.
Scott Kerman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 656
