Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel the tape that secures the display cable and touch-screen board-cable to the system board.
  2. Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  4. Place the computer face down on a flat surface.
    • Place the computer face down on a flat surface.
    • Remove the four screws (M2.5x2.5) that secure the display assembly to the palm-rest assembly.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the display assembly off the palm-rest assembly.
    • Lift the display assembly off the palm-rest assembly.
  7. Place the NEW display assembly face down on the palm-rest assembly. Place the NEW display assembly face down on the palm-rest assembly.
    • Place the NEW display assembly face down on the palm-rest assembly.
  8. Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  9. Replace the four screws (M2.5x2.5) that secure the display assembly to the palm-rest assembly.
    • Replace the four screws (M2.5x2.5) that secure the display assembly to the palm-rest assembly.
  10. Close the display and turn the computer over.
    • Close the display and turn the computer over.
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  11. Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Very nice post! That's a great website I have visited, thank you for your essentials words hotmail sign in
Martin Tolley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 31
Todo El Tiempo: 365
