Saltar al contenido principal
Dell Inspiron 5100 PP07L Memory Replacement
Qué necesitas
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: paso 1, imagen 1 de 1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: paso 2, imagen 1 de 1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: paso 3, imagen 1 de 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: paso 3, imagen 2 de 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: paso 3, imagen 3 de 3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Conclusión
2 personas más completaron esta guía.
May Chauvin
Miembro Desde 04/14/11
201 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-34, Maness Spring 2011 Miembro de Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 4,519
