Saltar al contenido principal
Dell Inspiron 5100 (2015) Thermal Paste Replacement
Qué necesitas
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: paso 1, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: paso 1, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: paso 1, imagen 3 de 3
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 2, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 2, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 2, imagen 3 de 3
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 3, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 3, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 3, imagen 3 de 3
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 4, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 4, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 4, imagen 3 de 3
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 5, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 5, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 5, imagen 3 de 3
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 6, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 6, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 6, imagen 3 de 3
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 7, imagen 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 7, imagen 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 7, imagen 3 de 3
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 8, imagen 1 de 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: paso 8, imagen 2 de 2
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
Conclusión
Una persona más ha completado esta guía.
Dominic Treadwell
Miembro Desde 07/09/23
184 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 26
Todo El Tiempo: 205
