Introducción
The function of random access memory (RAM) allows your PC to store files temporarily so that you can perform multiple tasks without having to close and reopen applications that you want to work on. Before diving into your PC, make sure you have an open, flat surface that isn’t carpet. Be sure you are not building up static electricity, so that you don’t damage any components.
Qué necesitas
Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
Unplug the power cable and remove any and all peripherals connected to PC.
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
Una persona más ha completado esta guía.
