Saltar al contenido principal
Dell Inspiron 3552 Hard Drive Replacement part 2
Qué necesitas
  1. Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: paso 1, imagen 1 de 3 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: paso 1, imagen 2 de 3 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: paso 1, imagen 3 de 3
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly
    • Open the latch and disconnect the hard-drive cable from the system board
    • Lift the hard-drive assembly off the palm-rest assembly
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift it off the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive
    • Connect the interposer to the hard-drive assembly
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly
    • Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Slide the hard-drive cable into the system-board connector and close the latch to secure the cable.
Conclusión
2 personas más completaron esta guía.
Jordon Dozier
Miembro Desde 02/10/21
1,663 Reputación
12 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 366
