Saltar al contenido principal
Dell Inspiron 3552 Hard Drive Replacement Part 1
Qué necesitas
  1. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the battery: paso 1, imagen 1 de 1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay
  2. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing optical drive: paso 2, imagen 1 de 1
    • Remove the screw that secures the optical-drive assembly to the base cover.
    • Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
    • Pull the optical-drive assembly out of the optical-drive bay.
  3. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: paso 3, imagen 1 de 2 Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: paso 3, imagen 2 de 2
    • Turn on the computer over and open the display
    • Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
    • Slide the keyboard up to release it from the slots on the palm-rest assembly.
    • Carefully turn the keyboard over and place it on the palm-rest assembly
  4. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: paso 4, imagen 1 de 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: paso 4, imagen 2 de 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: paso 4, imagen 3 de 3
    • Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
    • Open the latch and disconnect the optical-drive cable from its connector on the system board
    • Close the display and turn the computer over.
    • Remove the screws that secure the base cover to the palm-rest assembly
    • Using your fingertips, gently pry the base cover off the palm-rest assembly
  5. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing the base part 2: paso 5, imagen 1 de 1
    • Release the optical-drive interposer from the tabs on the base cover.
Conclusión
Una persona más ha completado esta guía.
Jordon Dozier
Miembro Desde 02/10/21
1,663 Reputación
12 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 939
