Saltar al contenido principal
Dell Inspiron 3542 Heat Sink Replacement
Qué necesitas
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: paso 1, imagen 1 de 2 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: paso 1, imagen 2 de 2
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: paso 2, imagen 1 de 2 Dell Inspiron 3542 Heat Sink Replacement: paso 2, imagen 2 de 2
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: paso 3, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 3, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 3, imagen 3 de 3
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: paso 4, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 4, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 4, imagen 3 de 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: paso 5, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 5, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 5, imagen 3 de 3
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: paso 6, imagen 1 de 2 Dell Inspiron 3542 Heat Sink Replacement: paso 6, imagen 2 de 2
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: paso 7, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 7, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 7, imagen 3 de 3
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: paso 8, imagen 1 de 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: paso 9, imagen 1 de 1
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: paso 10, imagen 1 de 1
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: paso 11, imagen 1 de 2 Dell Inspiron 3542 Heat Sink Replacement: paso 11, imagen 2 de 2
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: paso 12, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 12, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 12, imagen 3 de 3
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: paso 13, imagen 1 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 13, imagen 2 de 3 Dell Inspiron 3542 Heat Sink Replacement: paso 13, imagen 3 de 3
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
Conclusión
4 personas más completaron esta guía.
Rachel lindsey
Miembro Desde 03/21/17
733 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 24
Todo El Tiempo: 1,508
