Saltar al contenido principal
Dell Inspiron 3520 RAM Replacement
Qué necesitas
  1. Dell Inspiron 3520 RAM Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 3520 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 RAM Replacement: paso 2, imagen 1 de 3 Dell Inspiron 3520 RAM Replacement: paso 2, imagen 2 de 3 Dell Inspiron 3520 RAM Replacement: paso 2, imagen 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 RAM Replacement, Keyboard: paso 3, imagen 1 de 2 Dell Inspiron 3520 RAM Replacement, Keyboard: paso 3, imagen 2 de 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 RAM Replacement: paso 4, imagen 1 de 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron 3520 RAM Replacement: paso 5, imagen 2 de 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 RAM Replacement, RAM: paso 6, imagen 1 de 1
    • Locate the RAM chip(s)
    • There are no RAM chips present in this photo.
  7. Dell Inspiron 3520 RAM Replacement: paso 7, imagen 1 de 2 Dell Inspiron 3520 RAM Replacement: paso 7, imagen 2 de 2
    • There are two connecting pins for the lower chip.
    • There are two connecting pins for the upper chip.
    • Pull the pins away from the sides of the chip(s) to release it.
    • The chip(s) should slide away from the dock easily.
Conclusión
17 personas más completaron esta guía.
Ian
Miembro Desde 01/30/15
1,557 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-2, Watkins Winter 2015 Miembro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 69
Todo El Tiempo: 32,636
