Saltar al contenido principal
Dell Inspiron 3148 WLAN Card Replacement
Qué necesitas
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: paso 1, imagen 1 de 2 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: paso 1, imagen 2 de 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: paso 3, imagen 1 de 2 Dell Inspiron 3148 WLAN Card Replacement: paso 3, imagen 2 de 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: paso 4, imagen 1 de 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: paso 4, imagen 2 de 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: paso 4, imagen 3 de 3
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: paso 5, imagen 1 de 1
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: paso 6, imagen 1 de 2 Dell Inspiron 3148 WLAN Card Replacement: paso 6, imagen 2 de 2
    • Using your fingers, pull the WLAN card up and away from the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 286
