Saltar al contenido principal
Dell Inspiron 17R-N7010 Motherboard Replacement
Qué necesitas
  1. Dell Inspiron 17R-N7010 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: paso 3, imagen 1 de 3 Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: paso 3, imagen 2 de 3 Dell Inspiron 17R-N7010 Motherboard Replacement, Palm Rest: paso 3, imagen 3 de 3
    • Remove the four screws from the back panel.
    • Flip the laptop over and open it to view the keyboard.
    • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
  4. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 4, imagen 1 de 3 Dell Inspiron 17R-N7010 Motherboard Replacement: paso 4, imagen 2 de 3 Dell Inspiron 17R-N7010 Motherboard Replacement: paso 4, imagen 3 de 3
    • Close the laptop and flip it over so the bottom is facing upwards.
    • Remove the two screws from the small panel.
    • Remove the small back panel.
    • Slide the CD drive out of the laptop.
    • Remove the three screws from the CD drive slot.
  5. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 5, imagen 1 de 1
    • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
    • Remove the top cover by inserting a spudger under the surface.
    • Working clockwise, pry upwards with the spudger to detach the clips.
  6. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17R-N7010 Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect the ribbon cables.
    • Remove the cover to access the inner hardware of the laptop.
  7. Dell Inspiron 17R-N7010 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Make sure the SIM card has already been removed. If not, remove it now.
    • Carefully unplug the four ports connecting to the computer (the prying tool may come in handy when using it on the ports).
  8. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron 17R-N7010 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove all 10 screws on the motherboard using the Phillips #0 screwdriver.
  9. Dell Inspiron 17R-N7010 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron 17R-N7010 Motherboard Replacement: paso 9, imagen 2 de 2
    • Carefully lift the motherboard at an angle, and slowly pull out the final port.
    • You will find the port on the bottom of the motherboard shown in the first picture.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 1,430
