Introducción
You may want to remove the hard drive to upgrade to a higher capacity drive or if your files have become corrupted and unrecoverable.
Qué necesitas
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Remove the two 1mm double wide Phillips #00 screws.
Pull the hard drive away from the laptop.
3 personas más completaron esta guía.
