Saltar al contenido principal
Dell Inspiron 1721 Hinge Plate Cover Replacement
Qué necesitas
  1. Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: paso 2, imagen 1 de 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: paso 2, imagen 2 de 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: paso 2, imagen 3 de 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 175
