Saltar al contenido principal
Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement
Qué necesitas
  1. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, Base Cover: paso 1, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, Base Cover: paso 1, imagen 2 de 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 2, imagen 2 de 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 3, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 3, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 3, imagen 3 de 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 4, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 4, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 4, imagen 3 de 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, Internal Battery: paso 5, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, Internal Battery: paso 5, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, Internal Battery: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Detach the tab connecting the battery to the system board using your fingers or a pair of tweezers.
    • Peel off the adhesive tab holding the cable to the device.
  6. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 6, imagen 1 de 1
    • Flip the device over. Press and hold the power button for a few seconds to discharge any leftover electrical current.
    • You may leave the screen open if further repair is needed, or close it if you are only replacing the battery.
  7. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 7, imagen 3 de 3
    • Dell's official service manual does not mention of the 5th screw located near the middle edge of the battery closer to the touchpad.
    • Flip the device back over.
    • Remove five 3 mm screws that are securing the battery using a Phillips #0 screwdriver.
    • Lift the battery upwards to remove it completely.
  8. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, TouchPad: paso 8, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement, TouchPad: paso 8, imagen 2 de 2
    • Lift the latch holding down the ribbon cable connected to the touch pad.
    • When inserting the cable back, ensure that it goes under the white indents.
    • Remove the three screws holding down the bracket on the bottom portion of the touch pad using a Phillips #0 screwdriver.
    • Remove the four screws holding down the bracket on the upper portion of the touch pad using a Phillips #0 screwdriver.
    • Remove the bracket on the bottom portion of the touchpad by carefully peeling it away, as it is held by adhesives, then set it aside.
  9. Dell Inspiron 17" 7786 2-in-1 TouchPad Replacement: paso 9, imagen 1 de 1
    • Pull the small adhesive tabs to lift the touch pad away from the assembly.
Conclusión
Antonio Franco
Miembro Desde 08/25/22
1,025 Reputación
10 Guías creadas
Equipo
Gateway, Team 1-3, Class Fall 2022 Miembro de Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 175
