Saltar al contenido principal
Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement
Qué necesitas
  1. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Base Cover: paso 1, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Base Cover: paso 1, imagen 2 de 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 2, imagen 2 de 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 3, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 3, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 3, imagen 3 de 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 4, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 4, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 4, imagen 3 de 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement, Memory Modules (RAM): paso 5, imagen 1 de 1
    • Lift the cover to gain access to the memory module.
  6. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 6, imagen 2 de 2
    • Carefully open the securing clips on the end of each memory module slot until the module stick sticks up.
  7. Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17" 7786 2-in-1 Memory Modules (RAM) Replacement: paso 7, imagen 3 de 3
    • Remove the memory module by sliding it out of the slot.
Conclusión
Delia Padilla
Miembro Desde 08/23/22
564 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Class Fall 2022 Miembro de Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 128
