Saltar al contenido principal
Dell Inspiron 17-7737 Hard Disk Drive Replacement
Qué necesitas
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 2, imagen 1 de 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 2, imagen 2 de 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 2, imagen 3 de 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 3, imagen 1 de 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 4, imagen 1 de 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 4, imagen 2 de 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: paso 5, imagen 1 de 1
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 6, imagen 1 de 1
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 7, imagen 1 de 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 7, imagen 2 de 2
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 8, imagen 1 de 1
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: paso 9, imagen 1 de 1
    • Using the pull tab, lift the hard drive out of the cage.
Conclusión
Una persona más ha completado esta guía.
Mark Batista
Miembro Desde 03/16/23
457 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 39
Todo El Tiempo: 263
