Saltar al contenido principal
Dell Inspiron 17-5755 Motherboard Replacement
Qué necesitas
  1. Dell Inspiron 17-5755 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Motherboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 2, imagen 2 de 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Motherboard Replacement: paso 3, imagen 1 de 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Motherboard Replacement, Keyboard: paso 4, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Motherboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 6, imagen 2 de 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Motherboard Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 7, imagen 3 de 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Motherboard Replacement: paso 8, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 8, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 8, imagen 3 de 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 9, imagen 2 de 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
  10. Dell Inspiron 17-5755 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
  11. Dell Inspiron 17-5755 Motherboard Replacement: paso 11, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 11, imagen 2 de 2
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  12. Dell Inspiron 17-5755 Motherboard Replacement: paso 12, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 12, imagen 2 de 2
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  13. Dell Inspiron 17-5755 Motherboard Replacement: paso 13, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 13, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 13, imagen 3 de 3
    • Disconnect the hard drive ribbon cable from the laptop by lifting the latch which secures it.
  14. Dell Inspiron 17-5755 Motherboard Replacement: paso 14, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  15. Dell Inspiron 17-5755 Motherboard Replacement: paso 15, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 15, imagen 2 de 2
    • Carefully remove the hard drive and its assembly from the laptop.
  16. Dell Inspiron 17-5755 Motherboard Replacement: paso 16, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 16, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 16, imagen 3 de 3
    • Remove the 3mm screw which secures the wireless card bracket.
    • After removing the screw, remove the wireless card bracket, along with the antenna cables secured to the wireless card.
    • Afterwards, you may slide and remove the wireless card from the motherboard.
  17. Dell Inspiron 17-5755 Motherboard Replacement: paso 17, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 17, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 17, imagen 3 de 3
    • Gently spread apart the securing clips on each end of the memory-module slot until the memory module pops out.
    • Slide and remove the memory module afterwards.
  18. Dell Inspiron 17-5755 Motherboard Replacement: paso 18, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 18, imagen 2 de 2
    • Use a plastic opening tool to gently pry the CMOS battery found at the bottom right of the laptop out of the socket.
  19. Dell Inspiron 17-5755 Motherboard Replacement: paso 19, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 19, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 19, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
    • Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
    • Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
  20. Dell Inspiron 17-5755 Motherboard Replacement: paso 20, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 20, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 20, imagen 3 de 3
    • Lift the latch securing the optical drive ribbon cable, and disconnect it from the motherboard.
    • Afterwards, use a Phillips #0 screwdriver to remove the four 5mm screws.
  21. Dell Inspiron 17-5755 Motherboard Replacement: paso 21, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 21, imagen 2 de 2
    • Turn over the laptop, and safely disconnect the speaker cable.
  22. Dell Inspiron 17-5755 Motherboard Replacement: paso 22, imagen 1 de 1
    • Remove the antenna cables from the routing guides on the computer base.
  23. Dell Inspiron 17-5755 Motherboard Replacement: paso 23, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 23, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 15 screws that secure the computer base to the palm rest assembly.
    • Afterwards, safely pry the computer base from the palm rest assembly using a plastic opening tool.
    • There are 3 different screws used: Three 2mm screws on the edge of the optical drive, two 3mm screws located where the battery was, and ten 8mm screws.
  24. Dell Inspiron 17-5755 Motherboard Replacement: paso 24, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 24, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 5mm screw that secures the I/O board to the palm-rest assembly.
  25. Dell Inspiron 17-5755 Motherboard Replacement: paso 25, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 25, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 25, imagen 3 de 3
    • Lift the I/O board and turn it over.
    • Afterwards, lift the ZIF latch and disconnect the I/O-board cable from the I/O board.
  26. Dell Inspiron 17-5755 Motherboard Replacement: paso 26, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 26, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 26, imagen 3 de 3
    • Disconnect the fan cable from the motherboard.
    • Use a Phillips #0 screwdriver to remove the heat-sink screws in sequential order, as indicated by the numbers on the heat-sink assembly.
    • Afterwards lift the heat-sink assembly off the motherboard.
  27. Dell Inspiron 17-5755 Motherboard Replacement: paso 27, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 27, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 27, imagen 3 de 3
    • Turn the computer over and open the display as far as possible.
    • Lift the latches for the power button board cable and disconnect it along with the touchpad cable from the motherboard.
  28. Dell Inspiron 17-5755 Motherboard Replacement: paso 28, imagen 1 de 1
    • Close the display and turn the computer over.
    • Proceed to lift the latch which secures the ZIF display cable to the motherboard.
    • Disconnect the display cable from the motherboard.
  29. Dell Inspiron 17-5755 Motherboard Replacement: paso 29, imagen 1 de 2 Dell Inspiron 17-5755 Motherboard Replacement: paso 29, imagen 2 de 2
    • Use a Phillips# 0 screwdriver to remove the 3mm screw that secures the motherboard to the palm-rest assembly.
    • Afterwards, carefully peel the I/O board cable off the palm-rest assembly.
  30. Dell Inspiron 17-5755 Motherboard Replacement: paso 30, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 30, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 30, imagen 3 de 3
    • Turn the motherboard over.
    • Lift the latch to disconnect the I/O-board cable from the motherboard.
  31. Dell Inspiron 17-5755 Motherboard Replacement: paso 31, imagen 1 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 31, imagen 2 de 3 Dell Inspiron 17-5755 Motherboard Replacement: paso 31, imagen 3 de 3
    • Disconnect the power-adapter port cable from the motherboard.
    • Afterwards you may safely remove the motherboard from the laptop.
Conclusión
3 personas más completaron esta guía.
Jeff
Miembro Desde 02/15/17
385 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S6-G1, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 2,408
