Saltar al contenido principal
Dell Inspiron 17-5755 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: paso 2, imagen 2 de 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: paso 3, imagen 1 de 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: paso 6, imagen 2 de 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17-5755 Keyboard Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17-5755 Keyboard Replacement: paso 7, imagen 3 de 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: paso 8, imagen 1 de 3 Dell Inspiron 17-5755 Keyboard Replacement: paso 8, imagen 2 de 3 Dell Inspiron 17-5755 Keyboard Replacement: paso 8, imagen 3 de 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: paso 9, imagen 2 de 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
Conclusión
2 personas más completaron esta guía.
Gabriel Espinal
Miembro Desde 02/15/17
215 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G1, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 741
