Saltar al contenido principal
Dell Inspiron 17-5755 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 17-5755 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Hard Drive Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-5755 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Turn over your laptop and locate the two screws which secure the base cover.
    • Use a Phillips #0 screwdriver to unscrew the 8mm screws which secure the base cover.
  5. Dell Inspiron 17-5755 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Inspiron 17-5755 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  6. Dell Inspiron 17-5755 Hard Drive Replacement: paso 6, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 6, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 6, imagen 3 de 3
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  7. Dell Inspiron 17-5755 Hard Drive Replacement: paso 7, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 7, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 7, imagen 3 de 3
    • Locate the hard drive cable, and disconnect it from the laptop by lifting the latch which secures the cable.
  8. Dell Inspiron 17-5755 Hard Drive Replacement: paso 8, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  9. Dell Inspiron 17-5755 Hard Drive Replacement: paso 9, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 9, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 9, imagen 3 de 3
    • Carefully remove the hard drive and its assembly from the laptop.
  10. Dell Inspiron 17-5755 Hard Drive Replacement: paso 10, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 10, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 10, imagen 3 de 3
    • Remove the interposer by grabbing the black portion of the assembly, and pulling it away from the hard drive.
    • Be sure to not remove the interposer by pulling on the cable attached to it.
  11. Dell Inspiron 17-5755 Hard Drive Replacement: paso 11, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 4mm screws on either side of the hard drive assembly.
    • These screws are very small. Make sure not to misplace them.
  12. Dell Inspiron 17-5755 Hard Drive Replacement: paso 12, imagen 1 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 12, imagen 2 de 3 Dell Inspiron 17-5755 Hard Drive Replacement: paso 12, imagen 3 de 3
    • Safely remove the hard drive assembly from the hard drive to complete the process.
Conclusión
2 personas más completaron esta guía.
Jeff
Miembro Desde 02/15/17
385 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S6-G1, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Miembros
5 Guías creadas
2 comentarios
My question is, the hard drive is this a 7mm, 12mm or 15mm drive bay? I want to put a 4tb in my laptop but those are 15mm size and I can’t find what the size limit of the bay is.
Rachael Strange - Contestar
I want to put a 4tb harddrive in my laptop.
Those only come in 15mm.
will this drive bay hold 15mm sized drives?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 2,564
